Message 1 of 3
BT Box expiry
My Youview BT Box DT4000 has popped its clogs. It had been giving me the occasional blank screen and yesterday the screen went blank after a channel change, came back, froze the picture and then a permanent blank screen. Tried to do a maintenance reset but it failed to load or progress.
I need to ask for a new Box so to avoid the merry-go-round of phone numbers and options is there a go to number to ask for a replacement Box?
2 REPLIES 2
Message 2 of 3
Re: BT Box expiry
Hi @edbostan you'll get the contact details for TV technical support team on this link Fix EE TV | BT Help I'd recommend the message us option.
Neil
Message 3 of 3
Re: BT Box expiry
Thank you, Neil
