Message 1 of 2
BT TV Box
Power cut earlier today now only 1 blue light on the box and you view starts loading and then light goes red and it starts again
I have followed all the other stuff on resetting
new box
1 REPLY 1
Message 2 of 2
Re: BT TV Box
Hi @adeshaz I'm sorry about the delay getting back to you, did you manage to get this sorted?
If a factory reset hasn't worked a replacement box would likely need to be arranged.
Neil
