Message 1 of 3
BT Remote
Hi,
Apologies if this has been called out previously. I noticed tonight that when watching a recording on my BT box pro, pressing 00 on the remote takes you back to the start of the programme. 11 to about 10% of the way though, 22 to 20% and so on to 99 about 90% of the way through. It's instantaneous too, so much quicker than fast forward or rewind if you need it.
Cheers, Neil.
2 REPLIES 2
Message 2 of 3
Re: BT Remote
Great tip, actually you only need to press the numbers once.
0 is back to the start
1 is 10%
8 is 80%
etc.
Cheers
Steve
Message 3 of 3
Re: BT Remote
If you want to get to a particular minute in a programme, or at least as close as possible, put
the minute you want to reach/the duration of the programme
in the search bar of a browser, take the first digit after the decimal point, and use that as the input here.
Those of an agile mind may be able to do this in their head, as YouView clearly expected 😛
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
