Message 1 of 5
Bt pro box not powering up
Hi
I returned from holiday yesterday and my box won't turn on, I've tried unplugged it and rebooting it but no joy. I can't even get it in maintenence mode?
I've reported it just wondering if anyone has had the same problem?
4 REPLIES 4
Message 2 of 5
Re: Bt pro box not powering up
Hello 👋🏿
this isn’t a known issue, call BT Tech Team to run some checks on the box or see if they can send a Home Tech Expert Engineer out to have a look or replace it.
unfortunately if it’s not turning on then sounds like it’s faulty.
hope this helps 😊
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
Message 3 of 5
Hi @Dh40 and thanks for posting.
Sorry you're having problems with the Pro-Box. I would agree with @FIZZYLP . It sounds like the box has developed a fault. You can get in touch with the tech guys at Contact BT | Call us or chat online | BT Help.
Cheers
David
Message 4 of 5
Thanks, it's now been fixed, turns out the box is fine but the power cable was kaput
Message 5 of 5
That's great to hear @Dh40 . Thanks for letting us know.
Cheers
David
