Message 1 of 3
BT YouView Box & Packages
We're moving from Plusnet to BT full fibre at the end of the month.
We have a Plusnet YouView box & our question is whether or not we would be able to use this box if we decide to take any BT programme packages.
2 REPLIES 2
Message 2 of 3
Re: BT YouView Box & Packages
Hi @caravanj Thanks for posting, if you take out a BT TV subscription with BT we will provide you with a Pro box.
Neil
Message 3 of 3
@NeilO
Thanks for your reply.
I'll give it some more thought after the FTTP installation is done.
