Message 11 of 37
Re: Discovery+ contact provider to watch
That's brilliant. Thanks for confirming.
On the plus side, they managed to reply just in time before I trashed your account and started again, so we now know what we need to ask them to do to fix it for anyone else this affects.
Message 12 of 37
@DarrenDev Many thanks for your help getting this sorted.
Cheers
Neil
Message 13 of 37
Can you help me please? I have exactly the same issue. I’ve just tried signing out and back into the app - but no joy.
Message 14 of 37
I have the same problem too.  signed out and in again but nothing 😒
Message 15 of 37
For those still seeing this issue, please first go to www.bt.com/discoveryplus and attempt to activate your subscription there. It may redirect you to the new process via MyBT - if so, then follow those instructions.
It may say you've already claimed your account, but still offer you the chance to claim it again - do it anyway.
Once you've been through that journey, log out of the D+ app and then log in again.
If you're still having issues after that, please email me at [email protected] with your BT ID (the email address you log into MyBT with), and your Discovery+ ID (may also be the same email address). If you could also please let me know what message you were shown during the activation journey, that'd help.
Message 16 of 37
Thanks for this but when I click on the link you mention it takes me to the btsport link and I don't have btsport only the entertainment part of bttv
Is there a different link for the entertainment package?
Message 17 of 37
Log into www.bt.com/mybt and you should see an "Activate discovery+" option.
If you don't see that, then select "Your products", then "TV and sport". Do you see an option there to either activate or manage your discovery+ subscription?
Message 18 of 37
Hi Like i said i don't have BT Sport and when i go into bt tv it says my discovery plus is activated
Message 19 of 37
OK thanks. In which case, send me an email at [email protected]
Please include in that email:
The BT ID you logged into MyBT with.
The email address you activated the discovery+ subscription on.
I'll then ask the WBD support team to re-publish your subscription.
Message 20 of 37
Thanks  Darren
I've done this so fingers crossed
Melinda
