Message 11 of 18
Re: EE TV recorded programs cannot be fast-forwarded
no, just IP
Message 12 of 18
@PhilC42 @Brucemeister5
So anybody not having this problem, if they are in Aerial Mode, like me, that’s probably why they don’t see it,
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 13 of 18
A slightly different manifestation of the same problem on a T2100.  If I use the skip 30s button, randomly it kills the sound on the box - which can only be restored through a power cycle.
Ive got a second, spare, box and, after swapping them, the fault exists on the second box.  That was after a full factory reset on the spare box (it had been in the attic for a year or two).
I’ve not noticed any issue yet with the fast play button.  Just the skip.  Though possibly I haven’t used it enough.
j
Message 14 of 18
@powellj3
Try a Maintenance Mode - Keep Recordings on one or both, and see if this improves matters:-
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
Use the relevant instructions for your particular box model in each case.
Message 15 of 18
Done that. In fact the second box had a full factory reset.
Message 16 of 18
@PhilC42
I'm using IP mode and have never experienced not being able to FF during a recording (except for the recent bar on ad skipping on ITV channels).
It's worth a reset in Maintenance Mode (Keep Recordings) if you haven't already done so
Message 17 of 18
On my T4000 the sound occasionally mutes after using the skip function. But easily restored by doing a Pause then Play.
Message 18 of 18
@gomezz sadly, on my T2100, when the sound system fails, nothing but a power cycle will restore it.  This has been happening for only a few weeks.  Last night it happened twice in one programme.  So I resorted to using the fast-play buttons rather than the skip 30s button.  I had no issues whilst doing that.
