Message 11 of 13
Re: IPC6023 Error
@mjmc21 Have you tried connecting the TV box to the disc using the ethernet cable to see if that helps?
Neil
Message 12 of 13
Re: IPC6023 Error
Hi Neil, Yes that's exactly what I tried but there was no difference I'm afraid.
Any and all other suggestions 😁
Message 13 of 13
Re: IPC6023 Error
@mjmc21 I'll send you a private message and we'll be happy to help.
Neil
