Message 1 of 4
Lost thumbnails on BTTV android app.
Hi,
Since my app updated to version 4.6.1 last night, 24th May, I have lost all thumbnails in the 'My TV' section of the app. Is anyone else affected, or know of a solution?
Thanks.
3 REPLIES 3
Message 2 of 4
Re: Lost thumbnails on BTTV android app.
I have that too. It happened on version 4.6.0 for me. When the next update came through I thought it might be a fix for the problem.....
Message 3 of 4
Thanks guys - this was reported to me via email last night too. I've found the fault, and the server configuration should be fixed later today.
Sorry for the inconvenience.
Message 4 of 4
Thank you, much appreciated.
