Message 1 of 4
My BT 4K UHD
The box will not record any programmes. Is there a way of resetting it or do I have to get a new one
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: My BT 4K UHD
Hi @Harold79793544 Thanks for posting, I'm sorry you're having problems recording programmes. You can reset it following the guidance on this link 'How do I reset my BT TV box' Reply back and let me know if that helps.
Neil
Message 3 of 4
Re: My BT 4K UHD
Thanks for the info. I tried the reset but I still cannot record any programmes. Do you think I'II need a new box and what is the price of these boxes?.
Message 4 of 4
Re: My BT 4K UHD
Hi, @Harold79793544 It sounds like the hard drive might have gone faulty in the box. If you're within contract on your BT TV subscription a replacement box is free.
I'll send you a private message so you can get in touch and we'll help you. If it's urgent you can get in touch with the BT TV faults team on this link.
Neil
