Message 21 of 37
Re: No picture.
AI tells me that the Cello C32227F-LED Ver 2 TV was manufactured around 2016. This model is a 32-inch HD Ready LED TV with a built-in DVD player.
If this is true, does the dvd player work O:K
Message 22 of 37
Re: No picture.
Message 23 of 37
Re: No picture.
@zulu17 @Les-Gibson
Unusually though, no date given.
I did find a reference to this set posted in 2017, so 2016 may well be accurate; but if you told me it came from 2006, I’d almost believe you.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 24 of 37
Re: No picture.
@Midnight_Voice  looks like from data  on Amazon  the original version of the model was being sold late in 2014  (the ver2 may be a few years later).
Interesting that there is this mention in
https://forums.overclockers.co.uk/threads/cello-black-screen-problem.18822324/
Message 25 of 37
Re: No picture.
@Attheend  All the indications so far are that the EE TV box is functioning normally just that without a working Tv display you cannot see it.  So any existing recordings on the box should be watchable  once you have a working TV again. Also the box would continue to attempt any upcoming recordings you have scheduled and they should succeed assuming any aerial/broadband connections are there and the box is at least powered up in standby.  If you already have paired a mobile device with the EETV app you would even be able to setup up more recordings and monitor them.
Message 26 of 37
Re: No picture.
Thank you.
Message 27 of 37
Re: No picture.
I have dug through the files and it was purchased in 2014.
Message 28 of 37
Re: No picture.
Thank you. Cello are closed for the weekend but have sent an email to their support group so maybe will hear something Mon or so.
Message 29 of 37
Re: No picture.
Is it the Pro Box? I have found it very buggy with no picture or sound sometimes. Switching off at mains and turning back on cures the problem.
Message 30 of 37
Re: No picture.
@edbostan
@Attheend has confirmed that the problem occurs on the TV alone.
So the Box Pro, whatever its sins in general, is at least exonerated here.
