Message 41 of 49
Re: Do i have to return BT Youview box?
@Shawy Thanks for posting, I've sent you a private message so you can send over your details and we'll be happy to look into this for you.
Neil
Message 42 of 49
I am in the same boat. Been with BT ages and always had a BT TV box thing, almost 100% certain I've had it pre Dec 2019. I cancelled BT Sport in September 2022 and received the request/envelope to return the box.
I opened up a chat session and they confirmed I did not have to return it and I won't be charged.
(I fully expect to be charged but at least I have a transcript of the chat session when inevitably I have to request the charge back!)
Message 43 of 49
Hi All,
Sorry to ask the same question but I'm having the same problem. I have just stopped my bt TV but have had the box since 2016, but have been asked to return it. Might a moderator be able to help? @NeilO
Thank you
Cate
Message 44 of 49
I found it was worth ringing BT billing. Following my earlier post, I had a billing issue whereby after I had cancelled the BT TV package, I was still being charged for it some 2 months later. I rang them and got that issue sorted.
The agent then mentioned about the return of the box. I said how long I'd had it and that it should be considered to be mine, not loaned by BT. She agreed and noted the system accordingly. Within a few minutes of the call ending I received an email stating that BT had received my equipment back. Obviously they hadn't, but the agent had done what she needed to do to close the matter.
This way I have evidence that I need should it ever come to that.
Tags (1)
Message 45 of 49
Thank you.
@charlespw   I'll try that in the New Year
Cate
Message 46 of 49
Brief update.
I have contacted BT in the account and billing section via the online chat.
I have now been told I can keep my YouView box and it is now mine. I do not have to return it.
Many thanks to all for the advice and assistance.
Cate.
Tags (1)
Message 47 of 49
Having the same issues here.
I first took out BT TV way back in 2016 and decided to cancel at the weekend.
The sales assistant insisted I had to return the box and I’ve received an email today stating the same.
As far as I’m concerned, the box belongs to me and I can continue to use it as a basic YouView recorder and watch any basic Freeview recordings etc.
Not sure what to do or who to contact if they keep insisting I return it.
Message 48 of 49
A chat session is the way to go. Retain a copy of the chat for your records @Hendy2
Message 49 of 49
Hi @Hendy2 and thanks for posting. I can see @NeilO has r...
I can see @NeilO has replied to your question on your other thread at Solved: Leaving BT TV keeping box. - BT Community. As you've had the box for so long it's yours to keep. If you still getting messages to return it let me know.
Cheers
David
