Message 11 of 12
Re: ITV Hub not working on DTR-T2110
Many thanks Zulu17. I will try the factory reset & keep recordings option tomorrow & report results.
Message 12 of 12
Hi, I did the Maintenance Mode Factory Reset Keeping Recordings and it did the trick. All Apps are now working. Very many thanks for your help and clear instructions.
