Message 2 of 4
Recording stops
Does anyone know why when a program is being recorded on BT TV pro box and you start to watch  the program from the beginning before the recording has finished it stops recording from that point please?
3 REPLIES 3
Message 1 of 4
Fail to record
Getting numerous Fail to record messages especially foe Sky Sport programmes, is any one else?
Message 3 of 4
Re: Recording stops
@rnjmills Odd.   Mine doesn't do that.
Message 4 of 4
Re: Recording stops
Hi, @rnjmills welcome to the community and thanks for posting. I'm sorry to see you're experiencing problems with your recordings. Please can you try a factory reset, make sure to choose the option to keep your recordings and let me know if that helps?
Neil
