Message 1 of 4
Recordings
Can I watch programmes recorded on my bt tv pro box from my iPad?
3 REPLIES 3
Message 2 of 4
Re: Recordings
Hi @CabbyPatch1, welcome to the forum and thanks for posting.
This question has been asked before: Solved: Can I watch recordings from my BT box on my iPad a... - BT Community
Cheers
John
Message 3 of 4
Re: Recordings
It doesn’t answer what I want to ask, I may not have made myself clear.
my question is, if I have a recording on my BT box and I have the BT app on my iPad can I watch the recordings from my BT box via the BT app and then on my iPad?
Message 4 of 4
Re: Recordings
The accepted response on that topic does answer your query, but no you cannot recordings are only available on the box they're recorded on
