Message 1 of 13
Remote not fully working
My BT remote has suddenly stopped recording & controlling volume though other functions are all fine. I've changed batteries, rebooted the box several times, reset the remote & tried to reconnect remote using the LG code (only getting to step 5 each time - it would turn off TV but not back on)
  • Am out of ideas - any suggestions?
Tags (3)
12 REPLIES 12
Message 2 of 13
Re: Remote not fully working
Hi @ElleJay,
Thank you for posting. Which BT TV remote do you have?
If you have the BT TV Pro Box have your tired Resetting and Pairing your remote? This pairs the remote back with the BT TV Box using Bluetooth.
Thanks,
Paddy
Message 3 of 13
Yes, I've tried that (quite a few times!) and then when I followed the second set of instructions to re-pair the remote, it worked as far as instruction 5 - I put code in, turned off tv with TV button but it would not turn it back on, the OK button option didn't work either 🙁
Message 4 of 13
Hi @ElleJay,
Thank you for replying back. I think its safe to say your Remote is faulty. If you send me your details, I'll take a look at this and see if we can get a replacement one sent out.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 5 of 13
My BT remote isn't listed on the "which is your remote?" Page. I've tried all the different methods, but none reset the remote?
Message 6 of 13
My bt remote isn't on the list under "which BT remote do you have", and none of the methods seem to work, any ideas?
Message 7 of 13
Message 8 of 13
It's similar, albeit not identical to that, but the three button trick doesn't seem to do anything different
Message 9 of 13
Yours is maybe silver in the middle, and the purple button is black for you? It should function the same. Does the 3 button reset not cause the light to flash 3 times?
Message 10 of 13
That's right about the type but it doesn't flash when I hold the buttons down
