Message 11 of 14
Re: TV Box Pro and WiFi
Although not with  a BTTV box , I had a very similar issue recently with my LG TV , it had worked using WiFi with a SH2 , then I swapped to using an Ethernet cable as it was convenient to do so , but after decorating wanted to go back to using WiFi ( TV relocated so Ethernet cabling wouldn’t work ) , but the TV wouldn’t reconnect via WiFi , tried using WPS and by entering the log in credentials, it wouldn’t connect.
The problem was the hub ( or so it seemed ) , I can’t recall if it were a just power cycle or a full reset that was needed , but that resolved it , the TV is now connected wirelessly again .
Message 12 of 14
I only need one 🫤
At the moment maybe.  Always a good idea to have room for expansion.
Message 13 of 14
You can always get an ethernet splitter. I'm using a TP-Link one and it works fine, cost about £10
Message 14 of 14
A factory reset did the trick. Thanks for your help.
