Message 11 of 13
Re: TV Remote
Glad you were helped. It can be so frustrating chasing down info.
Message 12 of 13
Re: TV Remote
Top thanks to @naylor2006 for posting the info about the One for All URC1240 programmable remote available from Amazon (and presumably other reputable outlets)
Works perfectly with my Cello tv and EETV mini box in the bedroom, covering all functions on both, using the main codes for Cello tv and BTTV (look under Sat for this one) in the supplied comprehensive instruction and codes leaflets
Message 13 of 13
Re: TV Remote
Great news!
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
