Message 51 of 69
Re: Wrong itv region
e mail sent
thank you
Message 52 of 69
I have just setup my box and have exactly the same issue where I have BBC london rather than BBC Scotland
Can someone help
Message 53 of 69
When is your activation date @Piper95?
Message 54 of 69
It was today, everything else is working.
Message 55 of 69
Ok. Reboot your box tomorrow morning, then go into settings, TV Channels, then Update Channels. This works in almost all cases.
Message 56 of 69
Hi
I have the same issue. No option to change on the BT Box. Switched it off last night at the wall and it has made no differecnce.
Any other ideas?
Message 57 of 69
When is your activation date @iainrmackay ? It'll be in your order confirmation email.
Message 58 of 69
27th July 2023.....
The service was connected yesterday (30th October 2023).
Iain
Message 59 of 69
Not quite following you. You've had the box for over 3 months and just connected it yesterday?
It's the TV service activation date (not order date) that determines when your box will pick up the correct TV region - 24-48 hours after that date.
If it's been longer than 48 hours since activation date, email your BT account number to me at [email protected]
Message 60 of 69
Hi Darren
The activation date was 27/7/23. I'll send you an email.
Many thanks
Iain
