Message 11 of 48
Re: Youview missing apps
HI guys,
Thanks all for posting. Can you just confirm the following and we'll get this looked into.
> What is the exact box you have
> Can you view the channel normally (e.g. Channel 4)
> Have youtried rebooting the box and making sure it's on the latest software release
> Completed a soft factory reset
Cheers
David
Message 12 of 48
Hi. I can confirm that all the channels are working OK and available. All my normal featured apps are there and working except stv and channel 4 apps are missing in aerial set up mode but are there in iptv mode.I have the new Pro box. Connection is  wireless . Have done all the cable checks and factory reset several times. Really fed up watching the Rylan and Robbie video as I have seen it so many times the last few days.
Gordon
Message 13 of 48
Thanks for the feedback @Gss67
Cheers
David
Message 14 of 48
@DavidM
Hi
What is the exact box you have: BT Pro (model RTIW387)
Yes, I can view affected channels normally but as above, i) logo not showing, ii) backwards guide for these channels is blank and iii) future shows for these channels don't appear in "On Now & Later" after searching
> Have youtried rebooting the box and making sure it's on the latest software release.
Yes, I have reboot and have "Software up to date" and "You've got all the latest apps" messages
I need to run the box in aerial mode as IPTV mode is too limited in terms of simultaneous viewing/recording.
Many thanks
Message 15 of 48
Thanks @ChrisR6262
Cheers
David
Message 16 of 48
I was wondering if @DarrenDev might be able to help with this?
Cheers
David
Message 17 of 48
I've noticed our expert on this, but I doubt he'll see it before Monday.
Message 18 of 48
The response from YouView is that atmospheric conditions are causing boxes connected with aerial to switch to alternative regions - e.g. users near the border are picking up England TV regions instead of Scotland. Does this make sense to those in this thread who have lost STV? Are you near the border?
Message 19 of 48
Hi.
My tv signal is classed as central scotland and think the transmitter is midway between Glasgow and Edinburgh. I live around 7 miles west of Glasgow and around 100 miles from the border. Hopefully one day it will return to previous setting
Thanks Gordon
Message 20 of 48
Glasgow 👌 using Blackhill transmitter.
Thanks for your reply 👍
