Message 1 of 8
blaupunkt TV Remote code for youview
Hi all. We have a blaupunkt TV and had it so the bt remote worked for it. Had an issue and had to reset the remote so now need to add to TV again.
Does anyone have the correct code please?
7 REPLIES 7
Message 2 of 8
Re: blaupunkt TV Remote code for youview
Hi @Lindafenn, welcome to the forum and thanks for posting.
For the older BT TV boxes the Blaupunkt code is 2254. How do I control my TV with my BT TV remote control? | BT Help
Cheers
John
Message 3 of 8
Many thanks 😊
Message 4 of 8
Sadly no joy. The blue light on the remote is only flashing twice after I input the code and the tele isn’t switching off when I hold down the Tv button?
Message 5 of 8
I have BT Halo 3 so a fairly new hub?
the remote is only flashing twice after I put in the code?
Message 6 of 8
I did it. 0004 worked! Many thanks
Message 7 of 8
Apologies spoke too soon. TV turned off this time and back on but still can’t change channels, etc
Message 8 of 8
Hi, @Lindafenn I found an old post from a customer who used the Beko code 0556 successfully with a Blaupunkt TV. Give that a go and let me know how you get on.
Neil
