Message 1 of 5
re variable attenuator
I need an attenuator and have seen one at my local Toolstation.
However on the photo it seems to have screw threads on the aerial input / output. Will it still use the normal aerial connections?
4 REPLIES 4
Message 2 of 5
Re: re variable attenuator
@arbeeuk
Please edit out the direct website link, as its not permitted on this forum.
You could take a screenshot, and post that instead.
Its not suitable for the BT TV box as it has the wrong connectors.
Message 3 of 5
Thank you Keith
Anonymous
Not applicable
Message 4 of 5
@arbeeuk
I don't know the attenuator you are referring to, but from your description I would guess that they are "F" connectors, as used on satellite equipment.
B&Q sell one with suitable connectors, (known as "Belling-Lee), search their website for:
"Aerial Cable Variable Attenuator 0 20dB Coaxial Coax RF Digital TV Freeview"
Message 5 of 5
Yep, the Toolstation one, for satellite connectors. Needs a screwdriver to work it, so strike 2.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
