Message 11 of 18
Re: Advice re complaint sorting please
Thanks imjolly..... I did find the message envelope and read it, but can't find where to reply to it?
Edit:
I think I've sussed there isn't a 'Reply' to a message button, but rather use the blue 'Message' button to create a message to Linzi to reply to hers?
Is that the way to go?
Message 12 of 18
If you have managed to open the full message, there will be a "reply" button just underneath and this will come back to me directly @Doglover1
It should show like this:
Linzi
Message 13 of 18
Thanks @Doglover1 .  I have more than my fingers crossed!  Time will tell but so far the Guides have been great 🙂
Message 14 of 18
Hi Linzi.... no it doesn't look like that and I only had half of the message showing with no buttons.
Just PMd you  mentioning about not seeing the full message.
I wondered if it was because I was a new poster not being allowed to reply or something, like some forums do.
Message 15 of 18
Ric9380 - Well try not to trip up if you've  crossed your toes!
Message 16 of 18
Message 17 of 18
That's perfect @Doglover1 as I have your response.
If you hover over the title of the Private Message it will underline, from there you should be able to click this and it will open with the full message. You should then be able to see the reply option.
Linzi
Message 18 of 18
Thank you!
