Message 1 of 5
BT Cable Damaged my building
Hi
bit of an odd one, i have a BT cable fixed to my building with a metal plate and screws.
During the last storm the pressure on the cable has started to pull the lintel out from the window of the building.
I have tried to contact BT but no one can help or has any suggestions on who to speak to, can anyone help?
4 REPLIES 4
Message 2 of 5
Re: BT Cable Damaged my building
Does the cable supply you with phone and or broadband?
The cable is not the property of BT RETAIL. It may be the property of openreach
Message 3 of 5
You can report it here https://www.openreach.com/help-and-support/damage-health-and-safety.
Scroll down the page to the section
For any damage to your property caused by Openreach
Hope this helps.
Message 4 of 5
perfect thanks
Message 5 of 5
great thank you
