Message 21 of 58
Re: BT is blocking my website
What are you seeing? I can get there fine from BT
Steve
Message 22 of 58
Thanks Steve_M
Message 23 of 58
Thank you for checking. Screenshot below.
54a6549f-528f-4f7d-8272-42670ab15096.jfif
Message 24 of 58
Oh, that's different to this thread - we were seeing failures to resolve DNS.
What browser and version number is that?
Steve
Message 25 of 58
Thank you so much Steve
Message 26 of 58
Hi Astron,
It looks like you're having trouble connecting to the site because of a mismatch between the security settings on your browser and the server. However, I’ve been able to connect without issues, which suggests that the problem may be related to your specific browser or device settings. Here are a few things you can try to fix the issue:
1. Update your browser: Make sure you're using the latest version of your browser. Older versions might not support the most secure protocols or cipher suites that the site requires.
2. Clear your browser cache: Sometimes, cached data can cause connection problems, especially after a site’s security settings have been updated.
3. Try a different browser: Switching to a different browser (like Chrome, Firefox, or Edge) can help pinpoint if the issue is browser-specific.
4. Check your device's date and time settings: If your device’s system clock is off, it can cause SSL issues, as certificates depend on correct time settings.
5. Disable antivirus or firewall temporarily: Some antivirus or firewall settings might interfere with SSL connections. Temporarily disabling them (for testing purposes) could help determine if they are the cause. remember to turn it back on!
If none of these steps work, it’s possible that your system or network might be using older security settings that aren’t compatible with the website’s current configuration. You might want to check if your operating system and network security settings are up to date
Hope this helps, 🙂
Message 27 of 58
Thanks @Steve_M  and @dride .
It's chrome 129 on macOS.
Doesn't work on other browsers or devices, so not sure the issue is related to either.
Possibly a DNS caching issue? Have restarted the router, but no joy.
Message 28 of 58
It's definitely not DNS or routing - you are getting to the site fine, just unable to agree on an SSL cipher.
Have you tried the advice of @dride ? Is anyone else you know able to deplicate?
Steve
Message 29 of 58
Our website https://astron.health is still being blocked by BT. They are the only ISP blocking us, and there doesn't appear to be any clear way to get this resolved. Can somebody please help!
Message 30 of 58
I’m also encountering this issue right now with my website being blocked by BT. It’s frustrating because it’s critical for my work, and I’ve received similar reports from users on BT and EE who can’t access the site. I’ve tried changing DNS settings and contacting BT’s safebrowsing team as well, but so far, no response. Did you find any other ways to resolve this quickly? Here is the URL [removed] you can check and please please assist me as I am not a technical person. If anyone has insights or tips, I’d greatly appreciate them!
I can reach this website from a BT line, although looking at the content it may be being blocked by something else
