Message 1 of 5
External fibre cable fixings
Why is my external fibre cable fixing to my external wall different to my neighbours fixing? They were both done within 2 months of each other but a Kelly Communications operative noted that my connection is inadequate. Which is correct?My fixingMy fixingMy neighbour's fixingMy neighbour's fixing
4 REPLIES 4
Message 2 of 5
Re: External fibre cable fixings
A variety of fixing are used by Openreach , your neighbours wire is using a ‘swans neck’ to get the wire above the height of the roof tiles , your fixing is the more common used one , presumably the extra height gained from a swans neck isn’t necessary on your home but is necessary on your neighbours home , both fixings are correct in that they are proper authentic OR supplied fixtures, the circumstances dictate which type is used , just because they different doesn’t make one of them wrong
Message 3 of 5
Thank you. I'll sleep easier tonight.
Message 4 of 5
What they meant is your fibre clamp is undone (you can see the open section in the first picture). Plus that pigtail should have been swapped for a fixing with a closed eyelet.
Give your provider a call, you need an engineer visit asap to get that secured.
Message 5 of 5
