Message 11 of 19
Re: SUSPECTED BT LETTER THRU POST
You clearly didn't, so I'm out of this. Good luck.
Message 12 of 19
Will let you know the answer when I get a reply from BT themselves .... till them by by...
Message 13 of 19
@atttim
I have notified the moderators of the forum about this thread. They do not have account access so will not be able to directly help but they should be able to advise you who to contact or sent the letter to for verification as to whether or not is genuine or a scam of some sort.
They will advise you by posting on this thread.
Message 14 of 19
"Those of us with any common sense whatsoever, do shred anything with personal details on it"
But it's amazing how many people DO just throw away packaging with their name and address on it. Councils routinely use this to catch people who use the "wrong bin" for particular waste and to catch fly-tippers.
Message 15 of 19
Thank you so much
Message 16 of 19
Hi @atttim
Thanks for getting in touch and highlighting this, I can imagine it's worrying when you get a letter with incorrect details on it.
I'd recommend giving us a call so a guide can check to see if we've recently sent out any communication, and check if your direct debit is set up.
If you believe the email may not be genuine, you can take a picture or scan the letter and then send it in an email to our phishing team at [email protected]
Chris S
Message 17 of 19
I went to [email protected], link, and could not get anywhere in the BT System in that link where to send a BT LETTER, I repeat LETTER, it only applies to Emails and Phone devices, no help with Suspected Phishing BT Letters
Any further advice please ??
Message 18 of 19
As per what the moderator said in the above message.
If you believe the email (letter) may not be genuine, you can take a picture or scan the letter and then send it in an email to our phishing team at [email protected]
Message 19 of 19
Ok will will do as you suggest, thanks.
