Message 1 of 6
Account not set up correctly
Hi
I have recently subscribed to BT Broadband  and I am having following issuess:
1. When I log in I see two accounts, one of them is the old one that should be closed some years ago.
2. When I switch to my new account , under Your Products there are no products shown.
I would like to:
1. Remove my old, obsolete account.
2. Have Broadband added to My Products. Not having this set up prevents me from setting up My Extras, such as Parentall Controlls.
Thank you for your help.
5 REPLIES 5
Message 2 of 6
Re: Account not set up correctly
this is a customer help customer community forum and you post does not go to BT  try phoning CS 150 or 0800800150 from mobile and they should be able to help you
Message 3 of 6
Hi @borand,
Welcome back to the Community and thanks for posting.
If you haven't had the chance to call us you can reply to my PM and we'll be happy to look into this for you.
Thanks in advance
MandyF
Message 4 of 6
Hi MandyF
Thank you for getting in touch, I have sent you PM.
Kind Regards
Boran
Message 5 of 6
Hi @borand ,
Thanks for sending over the details. I'm glad I was able to get this sorted. Our BT.Com guys reset the account and added the information. Post back if you have any other problems.
Cheers
David
Message 6 of 6
Hi David
Thank you very much for all your help.
Kind Regards
Boran
