Message 1 of 6
Accounts
How do I delete three old BT accounts please
5 REPLIES 5
Message 2 of 6
Re: Accounts
Hi @ws,
If you are looking to remove accounts from your MyBT account, you can't do this. I can though. I'm sending you a private message so I can get this picked up for you during the week. When you reply back to my private message, please let me know the account that you wish to keep and I'll remove everything else.
DanielS
Message 3 of 6
Re: Accounts
Hi @ws, thanks for your PM and I've deleted the BTID now as no active accounts were linked to it.
Should you return to us in the future you can use the email address to set up a BTID then.
cheers
John
Message 4 of 6
Re: Accounts
Hi,many thanks for your speedy help and the resolution
Message 5 of 6
Re: Accounts
Hi John
Thank you once again for removing my BTID. I wonder if it is now possible to remove two email accounts that were associated?
Cheers
ws
Message 6 of 6
Re: Accounts
Hi @ws,
Thanks for reaching out to us again.
I have removed those emails from the public thread. I'll be working on Monday evening and I'll get rid of those email addresses for you.
DanielS
