Message 11 of 19
Re: Arrgh packages..
I've come for help, if people think that's a fair price for broadband, TV and Netflix then I will have to accept it. It just seems alot for 1 person usage
Message 12 of 19
No one is commenting on ‘fairness’ , and no one offers better deals for singletons compared to families , how on earth could  that ever  be verified.
 ‘basic’ EETV entertainment and Netflix currently is £2 for 6months then £24 after the March increase ( £24 that’s a more realistic price to base comparisons on ) add approx £30 for F2 broadband, that’s around £54 after the offer has expired, and could be considered a ‘fair’ price , hence asking you precisely what you have  and what you pay .
Message 13 of 19
@Lula2
BT do pile it on once you are out of contract, especially if your package includes that magic money maker called “Halo”.  Halo is a “free” upgrade that rapidly becomes a very expensive ornament.  Part of the key to a lower price is getting rid of it.
Six months ago, I was up to £110 including Part Fibre broadband (with Halo), phone, TV and mobile.
I couldn’t get BT to offer a decent price, so I initiate a move to Sky.  Sky screwed this up because they ignored my request for Openreach Full Fibre and sent CityFibre.  Unfortunately, there is a problem with a CityFibre install, (that I was already aware of), and so the install failed.
In the meantime, however, this seems to have provoked BT into making a sensible offer at last.  I cancelled with Sky, (but left the TV with them), and took BT’s offer.  £27 for Full Fibre 150 and pay as you go phone.  (The mobile is still with BT as well, but I’ve excluded that here).
It seems you have to demonstrate a willingness to actually move to get your point across.
Don’t know if that helps you or not, but good luck.
Message 14 of 19
Thank you that's very useful. Will give it a go
@WSH
Message 15 of 19
The point is that the packages are too broad, good value for those who have higher usage but hefty for low usage.
I have fairly basic needs! But can not get a basic package, apart from TV no frills. The broadband is the most costly out of the charges . I don't have any phones with bt.
@iniltous
Message 16 of 19
You need to stop everything such as Netflix and the TV package and just get a basic Broadband no landline package.
It does not matter if you are only low usage, you are not on a "Pay as you use" package. They don't exist, at least not with BT.
If you want a TV package, even if you only watch one TV program you will pay the same as someone who watches 24/7 which according to your Bill is costing you £27.33 per month.
If your contract is due for renewal, contact BT and speak to someone about it.
Do not be swayed by any sales talk and be aware that is you are still in a contract it is unlikely that you will be able to downgrade to a lesser package without taking out a new contract and paying cancellation fees
Message 17 of 19
£52.58 is your broadband cost ( going up by £4 at the end of March as everyones broadband price does )  , hence the increase in the assumed bill next month , but that is quite expensive for just broadband , you were asked to state what products you have , I suspect that whatever speed broadband you have it probably has Halo added, or you pay extra for Unbreakable broadband and ‘whole home WiFi’ the main components of Halo which quite easily turns an average broadband price into one over £50 , so it’s likely you are paying £20+ for that optional benefit.
Hopefully without sounding too patronising, you agreed to adding extras like Halo , so clearly you will pay more than someone with a basic broadband package , and similarly paying nearly £30 for TV is not a basic TV either , basic TV is free to air like Freeview.
If out of contract , you can negotiate a better price , check what a new customer would pay and use that as a guide , but without knowing exactly what you get for your money it can’t be known if the price you currently pay is good or bad, but if saving money is the most important thing , removing extras in your broadband (assuming you do have them) and removing ‘pay TV’ your bill could easily be around the £30-£34 area, not £80+.
 You initially said you wanted ‘no frills’  , if that’s the case , get rid of everything but basic broadband, but if you value the extras you have and want to keep them  , then you can’t expect to pay the same as someone with basic broadband.
Message 18 of 19
@iniltous
Too late you have been patronizing.
Like many others in many other forums, you have  a little bit of arrogance, underlying.
I do not know which broadband I have with name or number, would not know how to find it out!
I did not sign up for halo, my previous tv box was faulty and I was sent a new one.
Believe it or not I actually connected it myself!
I admit to being a tech dum dum but I have no interest apart from whether it works. I was born too early, but I have basic skills to do what I need to do. Refer to my grown up kids for help!
So thank you for your supercilious 'advice'. All finished
Message 19 of 19
Hi @Lula2
Welcome to the community.
I understand your post was more aimed at advice from other users, but if you'd like someone to look over your account, I recommend speaking with our customer support team. They'll be able to check everything for you from our side.
Chris
