Message 1 of 4
BT Halo 2 to 3+
I currently have the BT Halo 2 Broadband. What is the difference between this one and the new BT Halo 3 that is being offered.
3 REPLIES 3
Message 2 of 4
Re: BT Halo 2 to 3+
Halo 2 to Halo 3 has no extra benefits that I can think of, Halo 2 to Halo3+ does as you'll get the complete wi-fi benefits and also the hybrid connect.
The list of features can be found at www.bt.com/halo
Message 3 of 4
Re: BT Halo 2 to 3+
Thanks Richie,
They are offering the 3+ at a cheaper monthly price than I pay for the 2....strange
Message 4 of 4
Re: BT Halo 2 to 3+
@Mightymix69wrote:
Thanks Richie,
You'll only gain from the change of package as you'll get the hybrid and complete wi-fi benefits along with the perks you currently have, you'll also pay less you said, if you're happy then go for it.
