Message 1 of 2
BT TV essentials
Hi, I am paying £6 for BT TV essentials, can I cancel this but still want usual you view, I don't every use it and seems a waste of money, especially as the prices have gone up
Thanks in advance
1 REPLY 1
Message 2 of 2
Re: BT TV essentials
@mattyjoyce71
Depends.
If you cancel and the Youview box was received after 13/12/2019 then it's a loaned unit that must be returned when you cancel otherwise you'll be charged a fee.
If you had the box prior to the above date then it's yours to keep and use as a normal Freeview recorder.
