Message 1 of 3
BT Vision+ box
I have come across an old BT Vision+ box that is not used is it best to return this to BT or just recycle it?
2 REPLIES 2
Message 2 of 3
Re: BT Vision+ box
BT would only recycle it as well, if you can do that locally then go for it, you can also try https://www.recycleyourelectricals.org.uk/ to find something local.
Message 3 of 3
Re: BT Vision+ box
Hi @mw09, the guidance from @-Richie- is correct.
If you can't find a recycle centre near you post back and let us know and we'll arrange for you to return to us.
Cheers
John
