Message 1 of 4
BT contract expiring. Advice needed.
Good morning,
In October, my current BT contract expires. This is for broadband and landline.
If I chose to do nothing, am I correct in thinking that my broadband and landline services will just continue as normal, and I won't need to do anything?
Secondly, looking on the packages and offers page, I notice that there is an offer which is identical to the package I am on at the moment for broadband and calls. If I selected to sign-up to that package, would the contract start date begin immediately, and would the existing contract end immediately?
3 REPLIES 3
Message 2 of 4
Re: BT contract expiring. Advice needed.
Correct on all points
Message 3 of 4
One additional point.  If you let the contract expire it will continue but you may see a price rise, as you will lose any discounts you had under that contract.
Anonymous
Not applicable
Message 4 of 4
You'll probably find on line deals for those still in contact are just smoke and mirrors
Me? I'd wait till October , You'll be in a much stronger bargaining position then.
