Message 11 of 17
Re: BT keep cancelling order
@Es123
What is the name of the exchange? Without that, its not going to be possible to look up what is proposed by Openreach?
Message 12 of 17
Sorry! It’s Whitehaven
Message 13 of 17
@Es123
These are the fibre cabinets, some postcodes only have ADSL.
https://www.telecom-tariffs.co.uk/codelook.htm?xid=91443&postcodeloc=20019&cabinet=P2
Message 14 of 17
@Es123
I have also asked one of the moderators to post here, as they may be able to help.
They are very busy, so its likely to take a few working days for them to look at you order.
Message 15 of 17
Thanks for this, really helpful. It says 41% of our postcode is on the cabinet. Does that mean the remainder have fibre or don’t have broadband at all?
Message 16 of 17
@Es123
It just means that fibre (FTTC) is unavailable. There should be no problem ordering ADSL broadband, as there are no restrictions, unless there is a shortage of cable pairs.
The only people that are going to be able to look at this in detail, are the moderators, as they can look at your orders, and why they failed. I have asked them to respond here.
If its a problem with cable pairs, then you only other option may be 4G mobile broadband, assuming that you have coverage.
Message 17 of 17
Hi @Es123, sorry you've had trouble with your orders getting cancelled.
Have you managed to get an order placed for copper broadband as that should progress ok?
Cheers
John
