Message 11 of 13
Re: Been Told "Cabinet is full"
@Anonymous
I checked and they highest one I could get is with talk talk which advertises 11mb, still not enough i'm afraid. I will just have to wait till a spot opens, i'll keep checking daily
Anonymous
Not applicable
Message 12 of 13
@KB2173
Have you worked out what sort of speeds you both need to be able to work?
Have you considered Starlink - the satellite delivered internet?
It isn't cheap: a £449 one off charge for the equipment, then £75/month ongoing - though I'm not sure what speed you get for that.
Lots of info on their website:
https://www.starlink.com
Message 13 of 13
@Anonymous
Well at our last house we had 60 down and that was pretty good for both of us and worked quite well. I have considered starlink, I know it's mostly pointed to rural areas of which I am in. If nothing becomes available by the end of the year I think I might try it out
