Message 11 of 16
Re: Broadband query
@Kimberlin I suspect you were a politician in a former life, you never answer the question asked and just flog your same old mantra instead.
Message 12 of 16
Re: Broadband query
You are indeed a distinguished sage
Message 13 of 16
Re: Broadband query
They don't know the extent of your requirements until you discover yourself how many disks are required. They will then supply them on request.
Message 14 of 16
Re: Broadband query
They are now saying I need to doa power recycle. Hmm…
Message 15 of 16
Re: Broadband query
Tell them you've done one and would they please honour their commitment and send disks
Message 16 of 16
Re: Broadband query
Did you watch the video in the link , it details how to set up and position the initial WiFi disc and states the process to obtain up to 2 extra discs if the initial disc isn’t able to cover the entire property…TBH , it’s a little difficult to accept your complaint , most properties will only ever need 1 disc at most (  arguably the hub WiFi will be sufficient for most settings ) , so sending out 3 WiFi discs which is presumably what you expect ,  would be unnecessary.
