Message 1 of 3
Builders removed Master Socket from the house.
Hi,
The builders removed the master socket during demolition. I called BT and after 30 minutes waiting I was told that since I have broadband only (no landline) in order to have the Master Socket reinstalled I have to cancel my contract and make a new one and that I would have to pay a penalty fee for cancelling the actual contract. Isn't there a way to just pay for the service of installing a new master socket under the existing contract?
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Builders removed Master Socket from the house.
If openreach wiring still there then just try local paper for telecom engineer
If on FTTP then I would not bother
Message 3 of 3
If you need the master socket because your broadband is FTTC that requires you to plug the router into the socket , (possibly via a filter , possibility an interstitial master socket )  , and the lack of socket in effect means you have no broadband, simply report your broadband faulty , you may need to be creative when reporting the ‘fault’ , when the engineer is sent out , explain the issue, and they replace the missing socket , assuming that the wiring is still in place it should be an easy enough ‘repair’ .
Its likely to be a chargeable visit , but you seem prepared to accept that some cost is unavoidable.
