Message 1 of 9
Can't Restart BT Sport Monthly Pass
Hi,
I canceled my monthly pass back in November. I want to restart it now, but I can't find any option to do so anywhere in my account.
When I go to the Monthly pass page and log in as a returning customer, I'm sent to the homepage with no option to reactivate the pass.
Any suggestion on how to fix this? Looking through old posts I saw the suggestion of making a new account, but maybe by now there's a different way.
8 REPLIES 8
Message 2 of 9
Re: Can't Restart BT Sport Monthly Pass
Hi @EnricoM and welcome to our community.
Sorry you're having problems reactivating your monthly pass. What happens when you click on the 'Returning Customer' button on BT Sport Monthly Pass | Contract Free BT Sport | BT.
Cheers
David
Message 3 of 9
Hi @DavidM ,
thanks for the reply.
When I click on 'Returning Customer' and log in, I'm sent to my homepage. But there is no mention of Monthly Pass anywhere and no possibility of reactivating.
I canceled the Monthly Pass once before, and I remember that when I went to reactivate it, the option was there in my homepage and I did reactivate it without any issues. Now I can't see this option anywhere.
Cheers
Message 4 of 9
Hi, @EnricoM thanks for trying that, did you cancel it previously on MyBT or by contacting the helpdesk?
If you cancelled by contacting a helpdesk you'll need to follow the setup process as if you are a new customer on the BT sport monthly pass webpage.
Neil
Message 5 of 9
Hi @NeilO ,
I cancelled it on MyBT, but then contacted the helpdesk to ask for a refund because my subcription had just renewed that very day and I had forgotten to cancel it in time.
Should I still follow the setup process as a new customer as you suggest? And, in that case, do I have to essentially create a new account?
Cheers
Message 6 of 9
@EnricoM If the helpdesk was involved they may have deleted the service so yes I'd recommend following the registration process again as a new customer. Post back and let me know if that works ok.
Neil
Message 7 of 9
Thanks! I'll do it next week and report back with the result.
Cheers
Message 8 of 9
@NeilO  Just posting an update. Finally tried what you suggested and it worked just fine. I subscribed to Monthly Pass like a new client would do, but used my usual login and password. All good and now I have access as normal.
Thanks again for the help!
Cheers
Message 9 of 9
That's brilliant @EnricoM,.
I'm sorry that you needed to set it up again but I'm glad that worked for you.
Thanks,
DanielS
