Message 1 of 6
Can’t view bills or anything MyBT related
I cannot view any bills or Usage due to the following: Due to a temporary hitch at our end
I did make a call a while back about this and it was said there was another account linked which was removed and after logging back into the app was still unsuccessful.
5 REPLIES 5
Message 2 of 6
Re: Can’t view bills or anything MyBT related
Hi @Craig26
Welcome to the community.
How long have you had this problem for? Since the call you mentioned, have you been able to view your bills at all?
Chris
Message 3 of 6
I have had the problem over a year
Tags (1)
Message 4 of 6
Also not been able to view any bills since signing up for broadband
Message 5 of 6
OK, thanks @Craig26
It does sounds like it could be an issue with the way your account is set up. I recommend having another chat with our Customer Support team to see if they can get it sorted for you.
Chris
Message 6 of 6
Thank you
