Message 11 of 13
Re: Cancelled order
There are dozens of ISP that use Openreach infrastructure, there are many more providers than BT and EE on Openreach , @chrisjp is plain wrong to suggest that there is any place at all , that is limited to BT or EE , it’s just not true
https://www.openreach.com/fibre-broadband/fttp-providers
Although this is a list for  FTTP , the same open network principles apply to FTTC , any and every ISP that wants to utilise Openreach ( in exactly the same way as BT and EE on identical terms ) can and do .
Message 12 of 13
Re: Cancelled order
Okay, thanks for your time.
Message 13 of 13
Re: Cancelled order
Noted. Thank you.
