Message 11 of 28
Re: Cannot Access MyBT for Bill Access
Thanks Kimberly,
I managed to get a one of paper bill FOC.
They did want to charge me, but based on them being unable to provide what they offer (and the cost is already factored into your bill) they managed to waive the cost.
It did take me nearly 1 hour and being bounced around for them to admit there was an issue !!
A bit worrying that there team were unaware of the issue, even though I highlighted the 'ongoing problem' in my first message.
Hopefully it wasnt just lip service and it arrives.
Thanks for your input, it was appreciated 👍
Message 12 of 28
This isn't the solution though, it is a workaround as login to myBT is still not working.
Message 13 of 28
Correct, it isn't a work around, but it provides a solution for what I personally need.
If it helps others get what they need, then it works 👍
Message 14 of 28
Great at last after a month of no access to my bt account for bills information etc .just logged on at 10 pm tonight and everything is working as it should.as I said on my previous comment bt rep on telephone said it should be working fine on the 15th may .but it has come back tonight..
Message 15 of 28
Not working for me still but I do now get a 2FA text and then a page telling me there is an issue and they are working on it so some progress 😉
Message 16 of 28
Confirm all working OK for me this morning after no access for over a month.  Able to get to billing and all aspects of my account details.   Took 15 minutes to negotiate all the logon details and passwords etc but Hey Ho ... lets hope all's well from now on.
Message 17 of 28
It hasn't been fixed (19 May)
Message 18 of 28
I was told by a guide on the chat that a fix would be done by 28th May and they described the issue as an outage.
Message 19 of 28
I have been having the same issue along with apparently thousands of others. Tell them you want a paper bill because you can’t access online. They will send one free of charge. Certainly don’t pay.
Message 20 of 28
Having the same issue and it’s now well past 15th May ! Still no response from bt
