Message 1 of 3
Discounts / Discounts
Hi there.
When I check-out at the BT/EE Shop, I'm asked if I qualify for any of the available discounts : BT Employee, BT Pensioner, BT Shareholder.
Do any similar discount options exist, when I electronically recontract through MYBT ?
2 REPLIES 2
Message 2 of 3
Re: Discounts / Discounts
See https://store.ee.co.uk/help/managing-your-account/how-can-i-sign-up-for-the-bt-employee-or-bt-pensio...
These are discounts for employees those on a BT pension and shareholders
You then also have social tariff packages available for those that qualify
https://www.bt.com/broadband/home-essentials
Message 3 of 3
What I'm looking for, is the simplest way to recontract, within MYBT. Select 'Broadband', pick 'Call Package'; go to 'Check-Out', select 'Discount'; 'Sign-Up' & 'Finish'. Maybe, 'recontract' doesn't work that way: would be simple, if it did ?
