Message 1 of 4
Equipment Returns processing time?
Anyone know how long it normally takes to process once the equipment is delivered?
My RM tracking shows my hub was delivered on the 9th November but the order status still is showing 'Awaiting return'.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Equipment Returns processing time?
"Several weeks" was the last report. Just make sure you keep a screenshot of the RM delivery confirmation.
I'm assuming you meant November?
Message 3 of 4
I did yes (amended post), thanks. I was also sent 2 returns bags though a couple days apart from each other, which i hope doesnt cause any issues.
I will sit tight then for now.
Anonymous
Not applicable
Message 4 of 4
I'm attempting this on a mobile so may go haywire, but this was a recent post by a Mod.
https://community.bt.com/t5/Bills-Packages/Equipment-showing-as-not-returned/m-p/2327745#M162066
