Message 1 of 2
Equipment return
Could you please let me know how to return my kit? I have never received a return bag. The email from BT says, "We'll send you a replacement, free of charge. All you need to do is log into My BT and select 'Return your BT kit'", but there is no "Return your BT kit" option on the website.
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Equipment return
Hello,
can take up to 7 days to arrive plus been Christmas as well so may take longer then expected.
you have 60 days to return so no reason to panic.
The return your kit option will appear after 10 days of the 1st one being dispatched so please try again in due course.
if still unable to self serve and still not arrived you can contact BT to request another one anyways.
All the instructions are included inside the kit.
hope this helps!
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
