Message 1 of 7
Fail to Create / Activate an BT ID
We tried many times of creating/activating an BT ID since account setup in Nov 2023, but it still says fails due to technical issue. Also once received an email in Dec 2023 from BT that didn't witch on the services.
What should we do?
And will it affect my WiFi service?
6 REPLIES 6
Message 2 of 7
Re: Fail to Create / Activate an BT ID
Hi @owlivingco welcome to the community and thanks for posting. I'm sorry to see you're experiencing issues creating a BT ID. At what stage in the BT ID creation steps are you getting the error message?
Neil
Message 3 of 7
Thanks Neil.
The prompt displays when I do the final step - Security part.
Message 4 of 7
Hi @owlivingco
Thanks for your reply. Have you tried this on other browsers/devices just want to rule out a browser privacy setting?
Cheers
Stuart
Message 5 of 7
Hi @StuartH ,
Thanks for the suggestion. Tried both Chrome and Safari browser, but the prompt happens at the same step/stage.
Any advice? Thanks!
Message 6 of 7
Hi @owlivingco
Thanks for confirming this. I think this needs some further investigation.
I've sent you a private message asking for some more details.
Stuart
Message 7 of 7
Hi @StuartH
The information needed is replied via the private message.
Thank you for the support.
