Message 1 of 6
Fibre 2 ordered, appear to have Fibre 1
Hi all!
I upgraded from Fibre 1 to Fibre 2, the order closed today and it appears I'm still on Fibre 1.
I can see in my Hub Manager that my line is capable of faster speeds than I'm currently getting.
What can I do to get the upgrade to Fibre 2 sorted?
Thanks,
Senium
5 REPLIES 5
Message 2 of 6
Re: Fibre 2 ordered, appear to have Fibre 1
@Senium
I assume you've done an actual speed test & aren't just relying on the data figures.
https://speedtest.btwholesale.com
Message 3 of 6
@Senium
you certainly seem to be still on fibre 1 with up speed restricted to 10mb.  the upgrade will give a bit more down speed although not to even fibre1 max but big improvement in up speed
I have asked mods to help and they will post here
Message 4 of 6
Here's the result from the speed test:
This is the info I get from the broadband checker about what should be possible:
Message 5 of 6
@Senium I'm really sorry your speed hasn't improved since the upgrade, I'll send you a private message so you can get in touch with your details and the moderation team will be happy to help.
neil
Message 6 of 6
Hi @Senium, the order to update your profile has completed. Please will you check and confirm that you are seeing the improved upload.
Cheers
John
