Message 1 of 9
Final Bill
Hi, how long after my services have finished will I get my final bill please.
8 REPLIES 8
Message 2 of 9
Re: Final Bill
Typically 7 days after your services end, the final bill will calculate and be sent to you, weekends can delay it a day or so.
Anything previously advanced billed after the end date will be refunded.
Message 3 of 9
Re: Final Bill
Thanks Richie my services finished Fri 23 Sep 2022 so should I have a bill by now?
Message 4 of 9
Re: Final Bill
I would of thought so, if not any day.
How did you cancel, did you move to another provider or did you ask for the account ceased ?
Lastly, do you have any other services like BT mobile or are you using an email address provided by BT ?
Message 5 of 9
Re: Final Bill
After a lot of problems with them they said I could leave my contract (which should finish March 2023) without a fee so I did that.
I am now with another provider
My BT Mobile has stopped, I don't use the email with them.
Message 6 of 9
Re: Final Bill
You've still not answered my questions, did BT place a cease order to close your account or did you ask another provider to take over you line ?
If the account was ceased by BT, you would of received an email/letter stating what services were ending.
If you moved to another provider using the Openreach network, it should of been a working line takeover/transfer, BT would also send an email/letter notifying you of the takeover.
Message 7 of 9
Re: Final Bill
I received an email from BT stating which services were ending.
My new provider is not on the Openreach Network
Message 8 of 9
Re: Final Bill
Then it was cancelled manually by BT, does the cease email list all the services you had as ending ?
If so then the final bill is just delayed a bit, it does happen, have you checked online at www.bt.com/mybt to see if it was produced but you never got the email to notify you ?
If you don't see it by next week, speak with the billing team on 0800 800 150, they'll check and see what needs done.
Message 9 of 9
Re: Final Bill
Yes, the email does list all the services I had as ending.
I have checked on my bt.
I will leave it until next week as you say.
Thanks Richie
