Message 1 of 14
Halo 3, worth the upgrade?
Hello,
My current package is the Fibre 100. Got an option to upgrade to Halo 3 for an extra £1.75 a month.
Seems a no brainer, I guess the only downside is that he restarts my contract with BT which I don't mind really as its been good so far.
It mentions better coverage around the household? Any other perks?
13 REPLIES 13
Message 2 of 14
Re: Halo 3, worth the upgrade?
Hi @NICK90
Be careful of which add on benefit you are buying. You only get Complete WiFi if you add it to Halo 3 or get Halo 3+.
https://www.bt.com/help/broadband/learn-about-broadband/bt-halo/what-is-bt-halo-and-how-can-i-get-it...
https://www.bt.com/exp/halo?s_intcid=con_redirect_halo
Message 3 of 14
So it seems I get a "Tech Expert" but otherwise its exactly the same as what I have at the moment?
Even with the small charge it doesn't seem worth it. I would like this wifi disc for better coverage but you only get that with Halo3+ ?
Message 4 of 14
Hi @NICK90   Or as an add on to Halo 3. In which case the benefit is called Halo 3 with Complete WiFi.
Message 5 of 14
Currently I have Fibre 100, the upgrade is called Fibre 100 Halo 3. The benefits elaborate that I can stream on up to 12 devices but it does not state this in the Fibre 100 so I'm still slightly confused if I'm going to get better coverage with Halo 3.
Message 6 of 14
The full list of Halo3 and Halo3+ benefits are Here
Message 7 of 14
Complete WiFi is an add-on to your Broadband contract, nothing at all to do with Halo 3.  Complete WiFi has worked really well in this large house, well worth having, and Halo 3 worked just fine on the one and only service loss we have experienced.
Message 8 of 14
I had a conversation with a BT Agent and they advised me I have an engineer come once a year to check the line and there is a guarantee I will pay the same as a new customer on my renewal. Both does not bother me at all so even though it is only £1.70 odd a month more I'll just stay with my Fibre 100.
Thanks everyone 👍
Message 9 of 14
I'm not really clear on just what you have been offered but if the offer gives you both Complete WiFi and Halo 3 for just £1.70 I'd say definitely go for it.
Message 10 of 14
I have Fibre 100 and was offered Fibre 100 Halo 3. It does not come with complete WiFi.
