Message 1 of 3
Help referring a friend
Hi Moderator
Re Family and Friends £50 offer, do you have a contact for this please?
As the offer link tells me below but does not give me the link to share with daugter who is ordering BT Broadband today.  And I have no way to share the link with her.  Can you help please?
You're already signed up to refer your friends. You can get back to your sharing dashboard via any email we've sent you, or if you need a new copy of one, use the link below.
2 REPLIES 2
Message 2 of 3
Re: Help referring a friend
Hi @KayP
Welcome and thanks for your post.  I have moved your post to start your own discussion as the one you had posted on is already solved.
Sorry for the problems you're having referring your Daughter.  Here is the Refer a Friend link - Refer a Friend to BT Broadband
Can I just ask you to confirm whereabouts you're stuck?  Are you filling in the form on the right hand side and clicking on "start referring"?
Post back and we will take it from there.
Thanks,
Robbie
Message 3 of 3
Thanks Robbie as have not used the commuity link before.  Now got link will see if daughter can use it tomorrow.
